Issues in Azure ADSolved
3 years ago Jul 12, 2022
Hey kinda new here. Have been seeing people mentioning issues related to password changes in azure AD on other sites. Have any of you faced similar issues?
If you’ve got any recommendations or suggestions that’d be great. Cheers!
Replies (7)
From personal experience, I’d suggest you ensure Self-service password reset (SSPR) is set up for ur users and is monitored correctly. Once you get that right, chances of facing any of the common issues are lesser. Go through this documentation for some best practices of password management. Also, it would be a good idea to enable multi-factor verification for users either by changing user states or using conditional access policies.
Yaa like @v said first of all go through the deployment guide for setting up Azure AD Self-service password reset. This should help in keeping your deployment process smooth.
If u find ur users reporting issues like ‘contact your administrator’ and ‘we couldn’t verify your account’ when they try to reset password like our users had, ask them to check out this doc to find some common problems and its solutions. It’ll cover some common cases.
3 years ago Jul 13, 2022
Hi. We are having trouble with our azure AD users reporting they are not able to grant permissions to Hexnode azure directory services. Are we missing smthng here?
Hello @rae Welcome aboard to Hexnode Connect. Hope our community has helped you with the best practices you were looking for.
@sm Login with your admin account to the Azure Active Directory portal and follow the navigational aid:
Azure Active Directory > Enterprise applications > Consent and permissions
Check if ‘User consent settings’ is set to ‘Do not allow user consent’. If that is the case, users without admin privileges cannot grant the required permissions to Hexnode Azure Directory Services during device enrollment. To overcome this, ensure ‘User consent settings’ is set to either ‘Allow user consent for apps’ or ‘Allow user consent for apps from verified publishers, for selected permissions.’
For further documentation, refer to Azure AD Integration with Hexnode.
Hope this resolves your query. Should you need any further assistance, please do not hesitate to reach us!
Emma Jones
We’ve set the permission to allow user consent to apps and it’s all good now.
3 years ago Feb 23, 2023
interesting information
Hey Max, welcome to the Hexnode Community!
It’s good to see new faces *cough or names.
We are glad to see you getting comfortable around here.
If you need any assistance, all you need to do is ask. Our community members or moderators will be glad to help you out.
Warm Regards,
