Is there a way of clearing the files on a tablet?Solved
4 months ago
Hello everyone, is there a method to clear files on a tablet remotely without having to access them physically.
4 months ago
You can probably get it done using a script. Although, it’d depend on the Android version of your tablet, and also the location of the file you want to delete.
4 months ago
Thanks for the response. @Boris  It’s Android 10.
4 months ago
@Aitana  On an Android 10 device, you can use the following script to delete all files in the Download directory
del %sdcard%/Download/*
This will clear all files located under the Download folder.
4 months ago
Hello @Aitana , thanks for posting on Hexnode Connect.
To delete files from your managed Android device remotely, follow these steps:
  1. Navigate to the Manage tab in the Hexnode UEM console and select the desired Android device.
  1. Go to the File Explorer sub-tab and click Open File Explorer.
  1. You will see a list of folders and files on your device. Select the checkboxes next to the files you want to delete.
  1. Click on Actions and choose the Delete option.
  1. A confirmation popup will appear, click Delete to confirm.
Give this a try, and feel free to reach out if you encounter any issues. We’re always happy to help!
Hazel Smith
4 months ago
Hey, it worked for me! Thanks for providing a solution. @Hazel Smith
