Is it possible to customize kiosk mode app logo?Solved
4 years ago Dec 02, 2021
Hey guys…… I’ve managed to enable kioskk mode on a few android mobile. I was wondering if it was possible for the app in kiosk mode to be displayed with our company logo…….
tried using another mdm before running it by yours. but they don’t have that particular feature.
hopefully i won’t have to look for another solution for this..’
have you checked out launcher settings in kiosk mode in policies? There might be something there.
Thanks. I’ll check it out….
Hey Bennet,
Thanks for reaching out. It seems Zosia’s beat us to it. Fair play!
If you navigate to the Launcher settings in Policies > Kiosk Lockdown > Android Kiosk Lockdown, you’ll find the settings you need in the Customizations section. You can modify various settings from icon size to font size, title and of course, logo to fit your company’s logo and colors. Here’s a screenshot below just in case.
Android Kiosk Launcher Customize
I’m also attaching a link that redirects you to our help document on the Launcher section in Kiosk Lockdown. We hope this was helpful. Please reach out to us if you have any further questions.
Cheers,
Patrick Zimmerman
Hexnode UEM
4 years ago Dec 03, 2021
I found what I was looking for. Zosia helped me but I’m happy there’s instructions just in case.
thank you …
