Interaction with MDM android app with others applicationsSolved
Hi,
I want to know if it’s possible to query the android MDM app to retreive some informations about the device from our own enterprise app.
We need to know the UDID of the device so we can match the user to the device in our system. Since the device may be given to different user each day.
Or can we get the generating process of UDID done by hexnode so our own app can generate it too and use some server side code to change owner through the Hexnode API ?
Thank you for your help.
Alex.
Hey Alex,
You can check the UDID of a device from the Hexnode portal. Navigate to Manage Tab > Select your device > Click on Device info. The UDID of your device will be displayed in the Device info tab.
You can also add the UDID column in the Manage tab to easily view the UDID of all the devices without having to select each device and check for their UDID individually from the Device info tab. Follow the steps given below to edit the columns inside the Manage tab:
  1. Navigate to Manage tab and click on the edit icon present on the top-right corner of the device list table.
  2. From the Select Columns popup window, check the UDID option.
  3. Click on Done.
The UDID column will get added to the list of columns already present. This makes it so much easier for you to check the UDID of your devices.
However, you will not be able to fetch the UDID of the device from the Hexnode MDM app to your Enterprise application that is present in the device. You will have to check the required device details from the Device details page inside the Hexnode portal.
Hope this answers your query!
Chris Coleman
