Integration with Power Automate / Azure Logic Apps Connector?Solved
I’m trying to make a subset of Hexnode actions available to my users (e.g. wipe). For this I need to send API requests to Hexnode but it turns out with Power Automate alone it is super expensive. I then turned to Logic App but it wants me to create a OpenAPI / Postman Schema which seems time-consuming to recreate.
Does anybody else have similar experience integrating into the Microsoft products? Can I get this schema somewhere from Hexnode?
Hi there,
Hope you are doing well,
Hexnode MDM does provide you with a list of API calls that you can make use of in order to execute actions like the wipe device action in your systems including within Azure logic apps. This allows for robust integration of Hexnode actions with your internal systems.
Using this API integration, you would be able to execute the various actions provided by Hexnode, from within the Microsoft based tools and environment that is set up.
Here is a link to guide you through the API calls that are provided https://www.hexnode.com/mobile-device-management/api/
Here is a link for the API call along with the script required for the wipe device action https://www.hexnode.com/mobile-device-management/api/actions/wipe-device/
Please do try this out and check whether you are able to successfully integrate your environment with Hexnode.
Jeff Black
