Installing apps clicking from the deviceSolved
Why is that I need to click on each and every device to install the application I have set via Policies?
This is because the apps are not being silently installed on the devices. The silent installation of apps will not require any user interaction. This will eliminate the need of you manually clicking and downloading the apps to devices.
Silent app installation for Android devices is supported on Samsung Knox, LG GATE, KYOCERA. Silent installation is possible in case of generic Android devices if the device is:
  • Rooted or have Hexnode installed as a system app.
  • Enrolled in Android Enterprise.
Need more help? Have a look at the silent installation of applications in Android devices.
