Infinite pop-ups for Safari even though blocklist policy is not associatedSolved
1 month ago
Hi all, I’ve been using a custom configuration profile to allowlist a bunch of applications in all the user accounts on the device. However, after applying the policy, I switched to another standard account, and the device started showing endless popups from Safari Support saying it’s blocked. Any suggestions on how to fix this?
Safari Support popup after configuring policy via Hexnode UEM console.
1 month ago
Hey, why are you relying on a custom configuration profile for allowlisting? Why not just use the macOS allowlist policy?
1 month ago
The allowlist policy only applies to UEM-managed standard accounts, and we needed a solution to allowlist apps across all accounts.
1 month ago
Hmm, this could be an issue on Apple’s end, maybe?
1 month ago
Hi there, we ran into a similar problem. We resolved the Safari popup issue by allowlisting a couple of folders in the custom config profile. Try adding these:
/System/Cryptexes/App/System/Library/CoreServices
/System/Volumes/Preboot/Cryptexes/App/System/Library/CoreServices
Give it a shot!
1 month ago
Thank you so much! I’ve added those folders, and now the Safari popups have stopped. I did need to restart after applying the policy for it to take effect, though.
