How to upload certificates to be used in configuring active sync with Hexnode?Solved
while configuring Exchange active sync on iOS device, you can upload identity certificate. How to add this certificate to hexnode, so that they can be selected from the drop-down list?
You can add the certificate to the Hexnode portal and then later select it while configuring the Exchange ActiveSync policy.
To add the certificate:
  1. Navigate to iOS-> Security-> Certificates in the same policy that you are configuring Exchange ActiveSync.
  2. Click Configure. Click on Add Certificate and add the desired certificate.
  3. Now navigate to iOS-> Accounts-> Exchange ActiveSync and click on the drop-down list next to Identity Certificate. Added certificates will be displayed.
  4. Configure the desired settings. Associate targets and save the policy.
Please check out our help doc on adding certificates for more info.
