How to shut down the device after a few minutes?Solved
Want to shut down all the windows laptops in my organization after a few minutes. Possible with Hexnode?
There is an action to shut down devices in Hexnode. Not sure if u can schedule actions.
Hello Ida-sol,
The “Power off Device” action can be executed only on supervised iOS 10.3+, macOS 10.13+ and Android devices with Hexnode MDM as a system app. This action is used to shut down the device immediately.
You can deploy scripts on Windows 10 devices to achieve your purpose. Deploy a .bat script with the command,
By making changes to the last part of the command, you can delay the process. To shut down the device in 15 seconds,
Refer to our help documentation to know more about remote scripting on Windows devices. In addition, you can find the code snippets for the most commonly executed tasks in Windows in the script repository.
Hope that helps.
Deborah Timothy
