How to Retain Device Enrollment After a Factory Reset?Solved
12 months ago Jan 01, 2025
Hey guys, I’m managing a set of iOS and Android devices in my organization and was wondering — is it possible to mandate device enrollment after a factory reset?
12 months ago Jan 03, 2025
Hi @remi
Thanks for reaching out! Yes, you can ensure device re-enrollment after a factory reset, but it depends on the device type and the method of enrollment.
For iOS devices
  • Devices enrolled through Apple DEP will automatically re-enroll after a factory reset.
For Android devices
Let me know if you need more details!
Eden Pierce
12 months ago Jan 05, 2025
That’s helpful, @Eden. For Android, what happens to the device in the portal if it was enrolled using one of the other methods?
12 months ago Jan 08, 2025
Hi @remi
Great question! If the device was enrolled through other methods, Hexnode will no longer be able to manage it, though it will still be listed in the console. These devices must be manually re-enrolled to regain management.
Let me know if you need assistance with re-enrollment or anything else!
Eden Pierce
