How to restrict clipboard functionality on Zebra devicesSolved
4 weeks ago
We need to disable clipboard access on our Zebra devices (MC33 and TC52 running Android 8.1.0) for security reasons. We tried using Zebra OEM Config powered by MX, but it didn’t work. Is there another way to achieve this?
3 weeks ago
I had a similar requirement for restricting clipboard access on Zebra devices, and after testing, I found that using Legacy OEM Config worked effectively. When I set the Use of Clipboard option to Off, clipboard usage was blocked.
Even though the Cut and Copy options still showed up in certain areas, they didn’t function because the Paste option was entirely disabled. Since anything copied or cut couldn’t be pasted, it effectively prevented clipboard use.
This approach might work for you, give it a try!
3 weeks ago
Sounds great! We’ll give Legacy OEM Config a try and see how it works for us. I appreciate the insight!
