How to make kiosk more professional?Solved
Hello
have configured android tablets of company to work in kiosk mode. Any way to make the kiosk look more professional? It needs to look like a company asset and give out corporate vibes!!
Hi Dominic,
It is possible to customize the kiosk according to your needs. You can display an image and a title, say your company logo and name on the title bar of the kiosk home screen. And that’s not all. Options such as Title bar height, Logo height, Logo width, Title font, Title height, Title color, Title bar background color, and Logo-title alignment let you adjust the appearance of the title bar and its contents too. To customize the kiosk:
1) Open the kiosk policy and select Kiosk Lockdown > Launcher.
2) Navigate to Customization. Make changes according to your needs. Associate the policy with devices if not done already and Save the policy.
Refer to our doc on configuring kiosk launcher to know more. Apart from the title bar, the kiosk home screen can also be customized. You can choose to arrange the apps in any number of rows and columns.
1) Open the kiosk policy and select Multi App Kiosk.
2) Select Switch to Advanced View. Drag and drop the needed apps and files to the device screen shown in the portal. Scroll down and click on the Grid View icon. Select the dimension of the grid from the given option. Click on +Custom to get the grid in any dimension you want.
Hope that helps.
Cheers!!
Deborah Timothy
@Deborah Bingo!! got it. Thanks a lot.
Speaking about logos, our employees enroll their Mac to Hexnode using their AD credentials. They should see our logo instead of the usual stuff on the enrollment page in Safari. Possible?
Hi Earl,
Kindly refer to the thread on customizing the login page.
And that is just the tip of the iceberg. Check out Web Console Branding to bring about more customization.
Cheers!!
Deborah Timothy
