How to install fonts in Windows machine via Hexnode?Solved
9 months ago
9 months ago
Hi @aakash-shah
Thank you for reaching out to us. Unfortunately, Hexnode UEM currently does not offer a feature for installing fonts on Windows devices. We will explore alternative solutions and get back to you as soon as possible.
Eden Pierce
8 months ago
Hello @aakash-shah
Thank you for your patience. Although Hexnode UEM doesn’t have a built-in feature for font installation on Windows devices, you can use the “Execute Custom Script” feature to achieve this. Here is a script you can use:
Please ensure to replace the placeholders with the actual paths and URLs specific to your environment. The script will download the font, install it, and update the Windows registry accordingly. Additionally, a device restart is recommended after running the script to apply the changes.
Eden Pierce
