Can anyone explain how does the renaming devices can be done?
- Home
- Remote Actions
- How does renaming devices works with Hexnode
How does renaming devices works with HexnodeSolved
You can rename only supervised iOS devices. This name will be reflected on the device end as well.
Please follow the below steps for renaming the devices:
- Navigate to Manage > Devices and select the desired devices.
- Click on the Actions button and choose the option ‘Rename Device’. Type in the name. If multiple devices have been chosen and are to be named differently, check Append Number and set a starting number.
- Click Rename.
Please check out the help doc on renaming a device for more info.
Can wild cards be used while renaming a device?
Yes, Wildcards can be used while renaming a device enrolled in Hexnode console.
The following wildcards are supported:
- %devicename%
- %username%
- %deviceid%
- %email%
- %imei%
- %osname%
- %serialnumber%
- %osversion%
Please keep posting!
