How do you remove select users from a domain when applying policy?Solved
I handle quite a sizeable team of engineers with access to phones enrolled in Hexnode. All of them have been enrolled in the same domain. But I want to make sure a few of the team do not receive certain documents/apps which will be pushed to all the phones if I apply a policy to the domain. I have not found an option to exclude select users from the domain policy. Is there any way to do it?
You could maybe apply separate policies to the select devices that blacklists or prevents the users from accessing the docs sent to all domain users
That might be fine but wouldn’t it be a lot of work selecting the devices? There’s probably going to be a lot of confusion if I create a lot of new policies. Isn’t there any other way?
Hi Nicholas,
Thanks for reaching out. I understand you’re in a bit of a tricky situation with respect to pushing apps/documents to the right users. Fortunately, we have identified a viable solution to your problem.
Instead of applying a policy to a domain, you can apply it to a dynamic device group. Navigate to Manage > Device Groups > New Dynamic Group. You can apply the necessary filters, as shown in the screenshot below. In your case, the list would include all the devices whose users are part of your domain, with the exception of a select few users based on the criteria specified. The list will sync at regular intervals to keep the dynamic group regularly updated.
Dynamic Group Filters
After creating the dynamic device group, go to Policies > New Policy. After configuring your policy, navigate to Policy Targets > Device Groups and select the dynamic device group. Here is a screenshot below to help you along.
Dynamic Device Group Policy
The dynamic device group will ensure that applications, data, documents and whatever policy you desire will be passed to the devices fulfilling the criteria you have configured. This also saves you the hassle of creating multiple policies to exclude select users in the domain. Two birds, one stone.
We hope this solves your problem. Please get back to us if you have any further queries.
Patrick Zimmerman
Thank you. This was very helpful.
