Hiding and Locking apps on iOS 18Solved
2 years ago Sep 13, 2024
Hello,
With the recent iOS 18 update, I’ve seen mention of new features allowing users to lock and hide apps. In our organization, we issue iPhones to employees and want to prevent unauthorized access to certain apps containing sensitive information. Has anyone implemented these features in a business setting? How reliable are they for securing apps from unauthorized access?
Hi @tommy
We’ve recently implemented these features across our team for similar reasons, and they’ve proven quite effective. You can lock apps using Face ID, Touch ID, or your passcode to prevent unauthorized access. Here’s how it works:
  1. Long press the app.
  2. Tap Require Face ID (or Touch ID or Passcode).
  3. Tap Require Face ID (or Touch ID or Passcode) again to confirm.
Once locked, anyone trying to open the app will need to authenticate with Face ID (or Touch ID or Passcode).
And as for hiding the app, it follows a similar procedure: simply long press the app, tap Require Face ID (or Touch ID or Passcode), then tap Hide and Require Face ID (or Touch ID or Passcode). The app will be moved to a Hidden folder at the bottom of your App Library. To access the hidden apps in this folder, Face ID, Touch ID, or a passcode is required, ensuring only authorized users can see or access the hidden apps.
2 years ago Sep 16, 2024
I tried hiding pre-installed apps on my iPhone, but I wasn’t able to do it. I can hide apps that I downloaded from the App Store, though. Can we not hide apps that are pre-installed?
2 years ago Sep 18, 2024
Yes, you can only hide the apps you’ve downloaded separately from the App Store. Pre-installed apps cannot be hidden.
2 years ago Sep 20, 2024
Oh, okay. Is it the same for locking also?
2 years ago Sep 22, 2024
When it comes to locking apps, you can lock most of them, except for a few like Calculator, Camera, Clock, Contacts, Find My, Maps, Shortcuts, and Settings. Other than those, it’s definitely possible to lock the apps you need.
