Hi, I’m not able to install Hexnode MDM remote view. It says download failed.Solved
7 years ago
7 years ago
Hello Trudy,
You can try one or more of these options:
1.On your mobile device navigate to Settings > Security and enable ‘Unknown Sources’ option.
2.Try downloading the Hexnode Remote View apk file from      https://downloads.hexnode.com/HexnodeRemoteView.apk
3.Navigate to Admin > MDM Settings > Hexnode Remote View Settings. Enable the following options.
  • Enable Remote View.
  • Prompt user to install remote view app while in kiosk mode.
  • Make Remote View App Mandatory.
