Hexnode for work app lists an account called ‘Android Enterprise’Solved
4 years ago Oct 22, 2021
Howdy, folks!
I’ve a query. Noticed an Android Enterprise account being listed on the hexnode for work app while enrolling the device in AE (G Suite).
android enterprise account listed
I’m pretty sure no such account exists on the device. Should I choose this account? If yes, where do I get the password for it? First time postimg here, I’m wondering if anyone has seen this behaviour. Thanks
Same is the behaviour found.
Enrollment type: afw#hexnodemdm
Device: Samsung Knox
Version: Android 6
Authentication: Google User
This seems to the normal flow for Android. Quite familiar with it.
4 years ago Oct 25, 2021
Happy to help!
As @jake-wilson indicated, this is how Android OS behaves with Android Enterprise Device Owner enrollment using G Suite (Enrollment type as Google Domain, Enforce Authentication as Google User)
It usually occurs when you enter ‘afw#hexnodemdm’ as the device prompts for a Google account after the factory reset.
Afw enrollment for Android Enterprise - Device Owner
Android creates the account ‘Android Enterprise’ to hold the device owner privileges until the work account is added, or rather the Hexnode for Work app is set up to manage the device.
@tom You need not worry about this account nor its password. You can continue authenticating using your G Suite account. Once you are authenticated, this Android Enterprise account will be removed automatically.
Catherine George
