Hexnode APISolved
Does Hexnode have APIs?
Yes, it does. Hexnode API is available as a RESTful JSON implementation. This will work over authenticated, HTTP secured channels. The API is based on the HTTP protocol and you will be able to directly interact with it using any HTTP client library.
Hexnode API is mainly intended for application developers. It will provide an understanding of the design and architecture of the REST API library to facilitate the custom development and integration with Hexnode MDM.
To know more, kindly check out our help doc on Hexnode API.
