Hexnode Access, now on WindowsSolved
1 year ago
Hexnode Access is now available on Windows devices as well. Drumroll, please!! ??
In case you missed the buzz, here’s a quick recap of everything you can do with Hexnode Access:
  • Customize the login window
  • Configure network settings
  • Limit offline Access
  • Execute custom scripts on login
  • Add quick access links to help docs and step-by-step guides to help users with the enrolment process.
And in phase 1, Hexnode will support user login using Microsoft Entra ID and Google Workspace credentials. We’ll be expanding the scope to include more IdP providers in subsequent releases.
Hexnode Access for Windows
To ensure a smooth experience and minimize disruption, the feature will be rolled out in batches, and it might take a while for the feature to reach you. Meanwhile, you can check our documentation to get acquainted with the feature.
And as always, feel free to ping us here anytime you need help with the configurations or have further questions.
Happy testing,
