Yes, you can create two dynamic groups, one with devices whose missing app count is 5 and other with devices whose missing app count is 10. Follow the below steps for the same:
- Navigate to Manage tab-> Device Groups> New Dynamic Device Group.
- Add group name and description.
- Below Condition filters, you will have the option to create the criteria based on which the dynamic group is created.
- Select Compliance info as Column group and Missing apps count as Column.
- Choose Equal to as the comparator and then set the value of filter. Set the value as 5 while creating the first group and as 10 while creating the second.
- Click on Preview button to see the list of devices that meets the criteria.
- Click on Save group to save the details of the group.
Check out the help doc on Dynamic device groups for more info.
