Google Mobile Management being listed while configuring G Suite for AndroidSolved
While logging in to the Google Admin Console, Google Mobile Management being listed under Security > Manage EMM provider for Android? How can I remove this?
This could happen if the option ‘Use Google Mobile Management as your EMM provider’ was clicked previously. To remove this, login to the Google Admin Console. Navigate to Device Management > Setup > Android App Management. Click on remove, to disable Google Mobile Management as an EMM provider. Check the option ‘I understand and accept these changes’ and click on ‘DISABLE’ to remove Google Mobile Management.
Kindly use the link to get more info.
