Get notified when users have a weak password using HexnodeSolved
Can i generate a notification that would tell me if any users have weak password?
for example anyone under 10 characters
Yes, you can. Hexnode lets you configure password rule for devices. This will force the user to set a password that meets the requirements specified by the admin.
Hexnode lets you configure password rules for AndroidiOSmacOS and Windows devices.
Follow the below steps to set up password restrictions:
  1. Navigate to Policies-> Android/iOS/macOS/Windows-> Password and click Configure.
  2. Configure the displayed options for creating the password rule.
  3. Associate targets and save the policy.
The user will now receive a prompt asking to set a password as per the specified requirements.
If the user does not configure a password as per the requirements, the device can be marked as non-compliant. Also, the admin can be notified about the non-compliance. Please follow the below steps:
  1. Navigate to Admin-> General Settings-> Compliance Settings and enable the option ‘Device is not password compliant’. Click Save.
  2. Go to Admin-> Notifications and enable the option ‘Device out of compliance’ under Notify the administrators on. Click Save.
