Free trial contain full version of Hexnode?Solved
Are you able to tell me if the free trial that we test is a full verison, or only a shorter version?
When you sign up for the free trial you are assigned with the ultra-license which enables you to test all the features that Hexode provides.
You can switch between the plans and see the features under each plan by navigating to Admin-> License.
Kindly use the help link to know more about the same.
