Features supported by Fire OS in HexnodeSolved
Does Hexnode supports all the features in that of Android for Fire OS devices too?
Fire OS supports most of the features supported by Android except a few:
  • Hexnode for Work app is not supported.
  • The location mode should be set to High Accuracy to fetch the exact location.
  • Fire OS doesn’t support Enrollment using G Suite.
  • Fire OS doesn’t support Zero-Touch Enrollment.
  • Setting Wallpaper is device-specific.
  • Hexnode Browser is device-specific.
  • Kiosk Screensaver for Fire OS allows only images to be set as a screensaver.
  • Digital Signage for Fire OS supports only the streaming of images.
  • The restrictions Users can turn mobile data on/off, Users can choose preferred network type under Policies-> Kiosk Lockdown-> Android Kiosk Lockdown-> Peripheral Settings-> Network, are device-specific.
Kindly use the link for further info on the Fire OS and its difference from Android.
