Filtering devices with dynamic group – Android OS build versionSolved
I filter devices with dynamic groups. I’d like to filter devices based on OS build version. Is it possible?
I have 2 devices:
Android 11 (RP1A.200720.012.A326BXXU4AUK1)
and
Android 11 (RP1A.200720.012.A326BXXS4AVA1)
How to filter them out to be able to distinguish them?
Hi @Adrian,
Thank you so much for reaching out to us.
Unfortunately, Hexnode doesn’t have a setting right now to dynamically group devices based on the Build number. However, if you could explain your requirements furthermore, we could work on the subject to assist you with a plausible solution.
For the time being, you could check out several unique identifiers, such as serial number, UDID, etc., that might help you filter out your required devices. You can fetch such unique device identifiers from the Manage tab of your Hexnode portal. Also, feel free to visit our dynamic device grouping article if you think that might help.
Hope to hear from you soon. Have a great day!
Jeff Morrison
