Feature Request: Search and Multi-Select Action HistorySolved
Ideation
2 years ago
Two enhancments to make the Action History easier to use when diagnosing a problem:
1) Make the status drop down a multi-select instead of a single one. I’d like to be able to see pending and in progress actions at the same time, for example.
2) Add a free form search to the filter. I’d like to be able to easily see all of the actions that match a string or a regexp — particularly for the Action And Subject fields.
2 years ago
Hello @jeffgelb, welcome to Hexnode Connect!
We acknowledge your requirement and will take it up with the respective teams right away. Kindly bear with us for a while and we’ll keep you informed of the progress.
