Exporting ios app from xcodeSolved
8 years ago
What format should I be using when I export my ios app from xcode? Will Ad Hoc work?
8 years ago
Hi Lyric,
You should be using IPA file format. Sure, ad-hoc will work, but you’ve to provide the UDID of the devices if you are using Apple Developer Program. If you are on Apple Developer Enterprise program, you don’t need UDIDs.
