Exiting the Kiosk mode without a configured passwordSolved
7 years ago
Hello, if the password wasn’t configurated for kiosk mode is it possible to exit kiosk mode?
7 years ago
Hey Andrew! Well you don’t have to worry, there is a global kiosk password on the Hexnode MDM portal which is in general settings under the admin tab.
You can use the Global password mentioned to exit the kiosk mode in Android devices.
You can exit from the Kiosk mode using these simple methods:
For Android Devices:
https://www.hexnode.com/mobile-device-management/help/how-to-exit-android-kiosk-mode-in-hexnode-mdm/
For iOS Devices:
https://www.hexnode.com/mobile-device-management/help/disable-single-app-mode-ios-devices/
You can also view this video which explains how to exit Kiosk mode.
https://youtu.be/HmgGZqb-oM0
