Exclude domains through proxySolved
Can I exclude certain domains that need not be routed through the proxy for Samsung devices?
  • Please navigate to Policies –> Android–>Security.
  • Select ‘Global HTTP Proxy’. Click ‘Configure’.
  • You can see the several options that are to be configured for ensuring the data security for internet connectivity by re-directing it through a single proxy.
  • At the bottom will be the text box to enter the Domain/Hosts that are to be excluded from routing through the proxy server. Note to associate targets and save the policy.
The feature is supported only on Samsung Knox 2.5+ devices.
Kindly use the help link for Global HTTP Proxy.
