Enrolling Samsung DevicesSolved
5 years ago Mar 18, 2022
When we are enrolling Samsung devices to our MDM system, we have noticed that the default gallery application disappears this only occurs when we start the enrolment process from the QR code setup and not setting up the phone and enrolling by downloading the application from the play store.
We have also tried to push the application to devices afterwards but it flags that the application is not supported with the device, which is strange.
5 years ago Mar 21, 2022
Hey @Daniel,
Welcome to Hexnode Connect,
As per Samsung Knox, the Samsung Gallery app is no longer updated on the Google Play Store. Even if the app exists on the Play Store, the available version of the app could be incompatible with your devices. Moreover, on the higher versions of Android OS, for instance, Android 11, the Samsung Gallery app comes pre-installed as a system application. Hence, you need not install them on the devices explicitly.
To further explain your query with Android Enterprise Device Owner enrollment – system apps could be hidden after enrollment unless you specify it under the QR Code Settings.
Ensure the Enable system applications (Admin > Android Enterprise > Device Owner Settings (Android 7.0+) > QR Code Settings) option is ticked, and the settings are saved before getting the devices enrolled.
enable system applications – Android Enterprise Device Owner settings
Thus, except for the devices enrolled via QR Code setup, other devices have the Samsung Gallery app accessible. Kindly confirm the Android version and re-enroll the devices, considering the above settings. Feel free to contact us for more queries.
Catherine George
  • This reply was modified 4 years, 6 months ago by  Catherine.
5 years ago Mar 24, 2022
Hi Catherine,
Sorry for the delay, thank you for your assistance on this matter that has resolved the issue we had, and was something completely over looked during initial setup.
5 years ago Mar 25, 2022
Hey @Daniel,
Glad to have you back in the Hexnode Community!
We are looking forward to more inquiries, suggestions, and replies from you!
Always happy to help,
Catherine George
