Enhancements to Android kiosk exit settings in Hexnode APISolved
5 months ago
We’ve expanded the Android kiosk exit settings API with additional supported keys, offering more flexibility in managing kiosk mode exits.
What’s new?
The API now supports the following enhancements:
  • Kiosk manual exit – Allows users to manually exit kiosk mode.
  • Kiosk password – Defines a password for exiting kiosk mode.
  • Exit passcode tap count – Specifies the number of taps required to display the exit passcode prompt.
  • Exit kiosk with app open – Determines whether users can manually exit kiosk mode while an app is running.
  • Exit kiosk after reboot – Enables users to exit kiosk mode during the launch delay after a device reboot.
  • Relaunch app – Specifies a time delay after which the kiosk app automatically relaunches if the device exits kiosk mode after a reboot.
These enhancements provide IT admins with greater control over kiosk mode exit scenarios, improving the overall device management experience.
For any questions or feedback, reach out to us at support@hexnode.com or connect with us on Hexnode Connect.
Cheers,
Ben Clarke
