<span style=”font-weight: 400;”>Can i enable multi app Kiosk mode for iOS devices ? Any work arounds ?Please help.</span>
- Home
- Kiosk Management
- Enable multi app Kiosk mode for iOS devices
Enable multi app Kiosk mode for iOS devicesSolved
Sure you can.
On iOS, the multi-app Kiosk is basically whitelisting the apps you want to make available on the device. Check out our help article to know all about turning on multi-app Kiosk mode.
Is split-screen and slide over-view possible in iOS kiosk?
Hey Werner,
You will be able to access the split-screen view and slide-over view on iOS devices that are locked down using the multi-app kiosk mode. However, you will not be able to access the same inside single-app and web app kiosk modes.
Hope this clears your query.
Chris Coleman
