Does Hexnode support Kyocera business phones?Solved
6 years ago Apr 22, 2020
Our company has decided to order some kyocera devices. Want to know whether hexnode can manage these devices and make use of features supported by kyocera?
There is a list of Kyocera business device models that Hexnode supports. Hexnode’s integration with Kyocera enterprise SDK enables it to offer the advanced features supported by Kyocera.
There is a range of restrictions by Hexnode using which you can control the devices. You can turn on/off the functionalities like camera, blue tooth, Wi-Fi, etc on the devices. Other Hexnode features include enforcing location services, silent app installation, allowing mock locations, etc.
Please check out our help doc on Kyocera business phones for more info.
