does Hexnode MDM offer the normal MDM features as well such as VPP DEP and all that?
Hi, Joshua.
Hexnode MDM seamlessly integrates with VPP, DEP and many other enterprise programs. It’s not your regular Mobile Device Management suite, you have App management, web-filtering, geofencing, remote control, location tracking, Messenger and a lot more tools to easily manage mobility in your organization.
Have a look at the top Hexnode MDM features in here
That looks great! So, using this, we can automate iOS enrollment right? Like, with minimal interaction with the devices?
You can automatically deploy Apple devices using the Device Enrollment Program. The device gets immediately configured as it is switched on, avoiding the need to manually configuring it. Thus simplifies the initial setup of the devices.
Please note that the DEP enrollment is possible only on devices that are purchased directly from Apple or through any authorized resellers. Also, the organization must be enrolled in the Apple Deployment Program.
Need to know more? Check out DEP Management.
