Disallow modification of device name on MacSolved
9 months ago
We have deployed some macOS devices to employees, where the devices are named based on the employee’s team and department. We’ve noticed that some users have changed the names of their devices, which can create a lot of confusion for us (I mean for the IT team😅). It becomes challenging to keep track of the devices when associating policies with a specific team. Is there any way to restrict users from changing the device name?
8 months ago
Hey @wilma, as far as I know, if the user has a standard account, they cannot change the name of the device. If the user is an administrator, they will have the privilege to change the device name. Unless the administrator permits it, the standard user shouldn’t be able to change it, right?
8 months ago
Yes, that should be the case, but in our situation, standard users are also able to change the device name without being prompted to enter admin credentials. This might be a random case, but we still want a solution for this, either in the form of a script or a configuration profile or another.
8 months ago
Hi @wilma ,
Thanks for reaching out! We’ve got you covered, as Hexnode provides a restriction that prevents users from modifying the device name. Follow the below steps to configure the restriction:
  2. Navigate to Policies > New Policy, and assign a suitable name.
  3. Select macOS > Advanced Restrictions.
  4. Uncheck the ‘Users can modify Device Name’ option, which restricts users from changing the device name.
For more details, please refer to our help documentation on setting up macOS MDM restrictions.
Additionally, you can use the following configuration profile to restrict users from changing the device name:
You can utilize Hexnode’s Deploy Custom Configuration policy to deploy this configuration profile.
John Cooper
