Disabling Windows CoPilot – any solutions via Hexnode?Solved
2 years ago
Hello. Windows CoPilot has started appearing on our machines. Does anyone have a neat solution to remove/disable it via Hexnode?
Can disable via command line or powershell with:
reg add HKCU\Software\Policies\Microsoft\Windows\WindowsCopilot /v "TurnOffWindowsCopilot" /t REG_DWORD /f /d 1
But this doesn’t work with a script on Hexnode, and it also doesn’t remove CoPilot from the Taskbar.
Anyone got some suggestions for removing this?
2 years ago
Hello @Clyde,
Please execute the PowerShell script given below to disable Microsoft Copilot via Hexnode UEM:
Please try it out and let us know how it goes!
