Disabling Keyboard Shortcuts on iOSSolved
9 months ago
Hii everyone,
I disabled keyboard shortcuts in the policy restrictions, and it applied successfully. However, on the iPad, I can still see certain shortcuts on my device like curved leftward arrow and rightward arrow on the right bottom corner. Can anyone advise on what needs to be done?
9 months ago
Hello @Penelope  welcome to Hexnode Connect!
You might be referring to the undo and redo keyboard shortcuts. The ‘Keyboard shortcuts’ option under Policies > iOS > Advanced Restrictions does not disable these shortcuts. It can be used to enable or disable the text replacement feature, which can be found on the device under Settings > General > Keyboard > Text Replacement. I hope this helps. Feel free to contact us if you need any further clarification.
Hazel Smith
