Disable Zoom in Apple tv kioskSolved
Is there a way to disable zoom on Apple TV, while in single app kiosk mode?
Yes, there is. Please navigate to Policies. You can either create a new policy or choose to edit an existing one. Kiosk Lockdown > Apple TV Kiosk Lockdown >Single App > Advance Kiosk Settings. You will be able to find the ‘Enable Zoom’ option. The user can zoom the device screen only if this option is enabled (Not available when disable touch option is active). Please note to associate targets and save the policy.
Kindly use the help link to know more about the same.
