Disable VPN prompt for AndroidSolved
I need to disable the VPN prompt which comes while enrolling every new Android device
Hey, Thanks for reaching out to us. Happy to help.
Please navigate to Admin–>General Settings–>Data Restriction (Android). Disable the ‘Prompt to activate VPN’ option. When the option is checked, prompts to activate VPN on the device for mobile data management, during device enrollment and data restriction policies are applied on the device.
Click ‘Save’ at the bottom portion of the screen.
Kindly use the help link for more info on the General Settings.
