Hi @inez,
Thanks for reaching out. We have got the right fix for you.
With the App Notifications policy, you have several options to alert your employees when new mail arrives on their supervised iOS devices. Firstly, with the ‘Sounds Enabled’ option, you can enable notification sounds for the mail app to catch the attention of users immediately when new mail arrives. Also, you can allow the app notifications to be displayed even if ‘Do not disturb’ and ‘ringer’ settings are enabled on the device using the ‘Critical Alerts’ option. There is another setting ‘Alert Type > Modal Alert’ that helps you to show a persistent notification at the top of the screen, and employees must manually dismiss the notifications before continuing to use the device. Finally, you can select the ‘Show Notification in Lockscreen’ option to display notifications in the lock screen. In this way, you can ensure that your employees don’t miss any emails when they arrive.
Hope this helps.
Evin Lee
