Disable notification bar on AndroidSolved
7 years ago
I’m trying to configure an Android policy that disables the notification bar on tablets. Is that possible?
7 years ago
Hi Mike!
It is indeed possible to disable the notification bar via policy, but this feature is specific to Samsung Knox devices alone. Head onto Android Settings -> Advanced Restrictions -> Display Settings -> Enable Modify System Bars -> Enable Hide Status Bar.
If the devices are in Kiosk mode, you could disable the status bar from Kiosk Settings -> Peripheral Settings -> Enable status bar under Display settings.
For more details on different system configurations, refer to the Android Restrictions document.
Amy Watson
