Disable hexnode notification on androidSolved
I want to disable Hexnode notifications to my users on their Android devices. How do I go about doing that?
Hey, Thanks for reaching out.
I’m afraid you cannot disable Hexnode notifications alone on the devices.
Hexnode has the ‘Hide status bar’ option in ‘Advanced Restrictions’ for android devices. On enabling this option the access to the notifications bar and the quick settings tray will be denied. The status bar will be shown by default. Click here to know more about the Advanced restrictions
If the device is locked down to the kiosk mode, you have the ‘Lock task mode’ option under Peripheral settings in Android Kiosk lockdown. When the option is enabled it will disable the notifications and other configurable UI features and lock the device into an immersive kiosk. Click here to know more about the peripheral settings.
