Disable “Help Apple Improve Search”Solved
3 months ago
Hello everyone,
We are managing a bunch of macOS devices and we’re trying to lock down anything that sends data to Apple for privacy reasons. Specifically, I want to disable the “Help Apple Improve Search” option in Spotlight settings, but I couldn’t find any payload to manage this. Is there another way to disable this option?
3 months ago
Hey @wilma ,
I checked as well, but I couldn’t find any direct setting related to that. It’s not something I’ve come across before.
3 months ago
@marien “Help Apple Improve Search” option is only available on devices running macOS Sequoia and above.
@wilma , you can disable this setting by deploying a Configuration Profile. Here’s one that might help:
Let me know if this works for you!
3 months ago
Hey @remi , I just wanted to confirm that the configuration profile works perfectly!
