Different Lock- and homescreen wallpapersSolved
Ideation
Hi,
Is it possible to assign a different wallpaper to the lock screen than the one for the homescreen from the MDM? If not, is it possible to request the feature, because I am currently doing it by hand and that goes right until there is a policy update.
Hi Shaeme,
Hope you are doing well,
For your IOS devices, you would have the option to have unique wallpapers set for your lock screen and your home screen. You would be able to do this by configuring the policy from Policy > IOS > Wallpaper. From here, you would have the option to set the home screen and lock screen of the devices as you require. You may then add the required devices as targets and save the policy.
Here is a link to guide you through this https://www.hexnode.com/mobile-device-management/help/how-to-set-wallpaper-on-ios-devices-with-mdm/
For your Android devices, you would be able to set a single wallpaper and this would be applicable for both the home and the lock screen as well. Please note that the wallpaper that you set in the policy would overwrite the one previously set on the device, and hence each time you save the policy, both the home and lock screen shall be set to the wallpaper added to the policy.
We shall raise a feature request on your behalf for the option to set a different wallpaper for the home and lock screen. However, in the meantime, as a workaround, you could have a new policy with no other configurations, except the wallpaper set up.
Once this is done, you can then have this associated with the devices to ensure that they all have the same home screen and lock screen. After completing this, you can manually change either the lock screen or home screen to the one that you require. Since the wallpaper configurations are in a separate policy, it would not be saved frequently, and hence the wallpaper on the device would not be affected unless it is saved.
We understand that this is not ideal as it would require configurations to be set on the device end rather than remotely, but it would reduce the number of times the wallpaper is reset due to the policy being saved. You could try this out for the time being as we look into the feasibility of the feature to get it done remotely. Be rest assured that we shall keep you in the loop with updates on the possibility of this feature.
Stay safe and have a great day!
Jeff Black
Hexnode MDM.
2 years ago
Hi Jeff,
Do you have an update for me regarding the possibility of setting a different lock and home screen wallpaper on android devices?
Have a great day,
Shaeme
2 years ago
Hello @shaeme,
A feature that allows admins to set different wallpapers for the lock and home screens on Android devices has been raised and is in the works. We do not have a timeline just yet, but we’ll surely keep you in the loop.
2 years ago
Hi Chloe,
Has there been an update about the feature request?
Shaeme Suister
2 years ago
Hello @Shaeme,
We’ve accelerated the development of this feature; our team is working on it as we speak. It shouldn’t take long, but we will keep you updated!
