I do not want the Android device applications that are enrolled in Hexnode to have run-time permissions. How can this be blocked?
Deny app run time permissions for Android devicesSolved
Hi Noam,
You would be able to block the run time permissions for the apps by navigating to Policies -> Android -> Advanced restrictions -> App runtime permission -> Deny Permissions.
Please note that this works only for devices enrolled in Android Enterprise.
Another option would be to set up App permissions from Android -> App permissions. This works only for Android Enterprise devices and Managed Google apps.
Check out the help link to know more: https://www.hexnode.com/mobile-device-management/help/set-up-permissions-and-configurations-for-an-app-using-hexnode-mdm/
Cheers,
Eva Tyler
Thank you, Eva.
