It would be nice to have an option to delete an app cache and / or data, in the app management page, now it only allows to uninstall apps.
- Home
- App Management
- Delete app cache and data
Delete app cache and dataSolved
Hey there,
Could you please specify the platform you are planning to have this feature?
This would be very helpful on Android.
Hi Jono,
Thank you for getting back to us.
We can help you clear app data in specific Android devices. This can be done only on the devices which support Samsung Knox.
If your device is Knox compatible, you could navigate to Manage -> Select on a device -> Applications sub-tab. In this list, you could choose any app from the list, click on Settings -> Clear app data.
Please do have a look at our official help document on this topic.
You could refer to the below image if that helps!
Thomas Specter
This reply was modified 4 years, 10 months ago by
thomas-specter.
