Can Data Management details be exported using Hexnode?Solved
Can we export the data management details for an Android device?
Yes, you can. Please follow the below steps for the same:
  1. Please navigate to the Manage tab and click on the desired device. You will be directed to the Device Summary page.
  2. Navigate to the ‘Data Management’ sub-tab. You will be able to see the Data Management details of the device there.
  3. Click on the Export button at the top to export these details as a PDF/CSV file.
Also, you can export Data Management details from the Reports tab. Navigate to Reports-> Data Management Reports-> Devices and the Data Management details will be displayed. Click on the Export button at the top and you can choose whether to export the details as a PDF/CSV file. Click here to find more about the Reports.
