Customize the dock on Mac devicesSolved
Is it possible to customize the dock on Mac devices? Like adjusting the size and more?
Hi, Thanks for posting the question.
Please navigate to policies. You can create a new policy or edit an already existing one. Select macOS–>Configurations –>Dock. Click configure. You will be able to see the option to configure a list of settings related to the dock, including the dock size.
You can set the dock size using the dock size slider at the bottom portion. You can also disable the dock size slider on the device by enabling the ‘Disable the dock size slider’ option.
Kindly use the link for more info on the same.
