Creating a Group based on ProcessorSolved
7 days ago
Hey folks,
We manage a mix of personal Windows and Mac laptops, most of which run Windows VMs for work apps. We’re now trying to deploy an app to these VMs, but there’s a catch. Some run on Macs with Apple Silicon and need the ARM64 installer, while others on Windows laptops need the x64 version.
Is there a way in Hexnode to group or identify these devices based on processor architecture so we can deploy the correct version to each set?
Any suggestions are welcome!
Replies (7)
6 days ago
Hey, I think you can use dynamic device groups for that.
5 days ago
Yeah, we looked into dynamic groups, but I couldn’t find any tag or field that shows “Processor” info.
5 days ago
Hello!
It’s a bit of a workaround, but here’s what we did — we used a PowerShell script to detect the processor type (like “x64” or “ARM64”) and then manually added that info to each device’s Device Notes field.
The PowerShell script we used:
Once that’s done, you can create a dynamic group using something like:
  • Device Info > Platform, and
  • Device Info > Device Notes contains ‘ARM64’ (or ‘x64’).
It’s a bit of a hassle initially, but once set up, it makes grouping based on processor much easier.
4 days ago
That’s super helpful, thank you! We have used dynamic groups before, but didn’t even think of using the device notes field like that.
4 days ago
Where exactly do you find the Device Notes field? Is it visible by default, or do I need to enable something first?
3 days ago
Hey, you can find it in the device details page, there’s a section called Device Info. Device Notes is typically editable right from there.
3 days ago
Thanks much!
